Hi Guys,
Trying to do a throttle body reset with VCDS, but theres a few differences with what my screen shows to what i have seen on videos showing how to do it? I've managed to set anti-hijack so i believe i have a version which allows me to adapt things but if you see the image below, it doesn't mention throttle like the videos Ive seen. if you see the below image, those of you that have done it or use should hopefully see what i mean. Also, should it say NONE by label file?
The only thing i can tell might effect it is that i cant clear down the altitude adaption fault so would that affect it?
Thanks!
Thanks!
