VCDS Wigan
saveoursouls
415
234
36
Manchester
I’ve removed the vacuum pipe to my EGR in effect disabling the EGR. Wondered if there’s anyone close to Wigan than would be able to map it out with VCDS? Cheers
saveoursouls
415
234
36
Manchester
@saveoursouls are you sure you can do this with VCDS, Reason I ask is when I did a quick search on what to do they are all suggesting you cant do it with VCDS you need it to be mapped with other tools.
I know its not your car but this thread sums up what i have seen http://forums.tdiclub.com/showthread.php?t=271955 or this one https://www.audi-sport.net/xf/threads/mapping-out-egr.163858/ but happy to be proved wrong.
I’d just presumed that you could tbh, shame that it can’t be done with VCDS. I’ve re-enabled it for now as the car went into limp mode (it’s got an overboost problem that disabling the EGR aggravated further)
Deleted member 103408
Have you tried using the reducer pipe as suggested in the second link, just in case that helps you.
saveoursouls
415
234
36
Manchester
It’s on the back burner at the minute, car went into limp mode today due to turbo overboost, that was with the EGR connected. Tomorrows job is cleaning of the turbo.
