I’ve removed the vacuum pipe to my EGR in effect disabling the EGR. Wondered if there’s anyone close to Wigan than would be able to map it out with VCDS? Cheers
@saveoursouls are you sure you can do this with VCDS, Reason I ask is when I did a quick search on what to do they are all suggesting you cant do it with VCDS you need it to be mapped with other tools.
I’d just presumed that you could tbh, shame that it can’t be done with VCDS. I’ve re-enabled it for now as the car went into limp mode (it’s got an overboost problem that disabling the EGR aggravated further)
It’s on the back burner at the minute, car went into limp mode today due to turbo overboost, that was with the EGR connected. Tomorrows job is cleaning of the turbo.
