vibration when letting off between 2500-3000rpm
arronleeds
192
I have been getting a vibration through the front end end and in the steering wheel if im at say 2k rpm and let off the throttle at 2800/3000rpm after giving it some. it only does it in this rpm range and it doesnt matter what gear im in, im confused to as what it could be. anyone had this before? its rpm related and only does it if i give it some within this rpm range, if i drive sensible it doesnt happen.
arronleeds
192
Curiosly, do you get vibration when idling?
I do sometimes, but it goes when I turn the AC off 🤷🏼‍♂️
i do get a little as i have a powerflex hybrid bush, the issue i have was there before too.
H Rafiq
951
382
Manuel or DSG? DSG serviced recently if DSG? Any rough idle or jerkiness?
arronleeds
192
Dsg and was serviced by vw at 38k miles, issue was there before and I never realised it was an issue until recently where I’ve managed to replicate it numerous times.
arronleeds
192
Surely humour is allowed. Didn't you see the smiley at the end.
I saw a thumbs up no smiley, I’m just in a foul mood, sick of the car, it’s got warranty and twice I have been fobbed off by main dealers, they’re useless.
GORDYDJ
59
7
Know how you feel. Last car was a MK1 Citreon C4. Just changing the air filter involved removing the wiper arms, scuttle panel and a couple of air intake pipes. Even after all that you still risked grazed knuckles getting it out from the back of the engine. As for the heater blower resistor. You needed arms thinner than a grass snake's waist. As for doing work for MOT. Between lack of access & seized nuts/bolts I was about to give up. The final straw came when I lost the keys. At £250 to replace them I decided time to throw in the towel and send her off to the crusher.
mty12345
3,775
478
bristol
Could be inner cv joints where the driveshafts go into the gearbox. They often give that symptom of vibration only at certain RPM or under deceleration etc
Reactions: GORDYDJ
arronleeds
192
Noticed the vibration since 37k when I bought it and it’s on 42k now, I wouldn’t expect something like that to be damaged so soon but you never know these days. Is it an expensive job
Deleted member 139706
Does it do it in neutral too? Could be early signs of DMF failure...
arronleeds
192
Can’t replicate it in neutral, I have been to the main dealers twice now for what I believe could be flywheel failing, when car comes to a stop, 2-1 I hear a chatter and I can replicate it by blipping throttle while reversing. Even though I showed the dealers a video of the issue they told me “we can’t replicate it” I wasn’t happy and they were due to call me back last week and as usual no call back.
mty12345
3,775
478
bristol
The joints are under a lot of stress having to transmit not only the power, but deal with the movement of the driveshafts at the same time. It could be something else, but that would definitely be my best guess given the symptoms.
Shouldn't be too expensive if that is the problem. May be able to get away with just replacing one shaft, and it's usually only an hour or so labour to swap a driveshaft on most cars.
