VR6 clutch and G60 flywheel
wazza16
Mr.Waz
Aug 19, 2010
241
Arbroath
just looking in to this as a possible upgrade next year, is this setup a direct replacement from standard? where do u guys get ur flywheel and clutch from? and wat kinda price for them? i would fit it myself so labour isnt an issue! cheers
ibizatom
Warrrrp tish
Mar 13, 2010
328
Kent
My car has been through a few clutches due to the torque I am running including the VR6 clutch.
I have a petrol FR pushing around 244bhp and 305lbs torque. Flywheel is standard but the car now has Stage 1 Organic Helix clutch. As far as I know (could be wrong here) but it's rated to around 400lbs torque.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Yep, direct replacement for your OEM clutch/flywheel.
You will need some new bolts to go with it too. Do a search as all the part numbers are out there.
wazza16
Mr.Waz
Aug 19, 2010
241
Arbroath
kewl, Vr6 clutch suitable for my stage 2? say 240bhp and 260lb/ft? need bolts for the flywheel ye? wat weight would i get it lightnened to about 6 kg?
Damoegan
Oct 15, 2007
8,993
Newcastle
Think the VR6 clutch is rated to 300lb/ft. I was running this setup when pushing the boundrys of stage 2 and it was a very nice clutch..
May 6, 2009
3,500
Northallerton, N yorks
Do a search on google mate, everything is out there on many a forum. 6kg's seems to be the optimum weight though, any lighter and they can get abit rattly etc mines 6kg's and still idles like its standard.
Keep a look out for secondhand flywheel cheap, then vr6 sachs or luk clutches are about 120 quid, all bolts, both flywheel and clutch cover bolts are around a tenner. Then you just need to get the flywheel lightened and then clutch cover and flywheel balanced by an engineering company.
wazza16
Mr.Waz
Aug 19, 2010
241
Arbroath
ye seen on ur thread u had it lightned to 6 kg, so all in is reletively cheap then, prob need done after a trip to big fish and launch control hahaha ye there is a place local to me that specialize in engine building, agra? ill have a search about for bolts and kit if need a hand ill give u guys a shout!! cheers lads
nossi_20v
106
Teesside
Heres the up to date part numbers for everything you need bud...
G60 flywheel - 028105269bx
sachs vr6 clutch kit - 3000384001comes with new release bearing
shorter bolts for flywheel (x6) - n90206103
clutch pressure plate bolts (x6) - n10101001
Ohh and if you order new clutch without release bearing i think the release bearing for the 1.8t clutch is same as one used with vr6 clutch and if so the part number is 07376.
Hope that helps you:)
nossi_20v
106
Teesside
Got the brakes fitted today bud then its going back in friday to get clutch fitted cant wait to get it bk bin without it three weeks now! picked up flywheel off ur boss tonight well impressed with it looks half the size ha! some nice bits in that workshop that manifold with two wastegates is ****!
May 6, 2009
3,500
haha its offit isnt it, proper awesome mani! You look in the engine workshop at all or round the back at the e-type race car? Glad it all got sorted, shame the balancing company didnt get it back in time. Wont be long now though mate :D
wazza16
Mr.Waz
Aug 19, 2010
241
Arbroath
cheers nosi great help, your cup looks nice def the best colour anyway haha! ur standard clutch die with the power ur putting out, be the same figures im goin for to buddy, who is it that mapped urs?
Damoegan
Oct 15, 2007
8,993
Newcastle
......Ohh and if you order new clutch without release bearing i think the release bearing for the 1.8t clutch is same as one used with vr6 clutch and if so the part number is 07376.
Yep, both the same release bearings. I used the VR6 one when I fitted mine.
