knight85
Money spending clown
Dec 30, 2008
2,222
South East
just a quick question. My car is going in for a few bits and bobs under warrenty to do with the electrics...
will they detect my remap and also will they wipe it? slightly worried i may lose it? :shrug:
thanks
hmmmm,
had the remap for over 10k now and not a problem with that. The faults are fairly basic:
no intermittent wipers
no indicator light flash when locking the car
no 'one touch' up for electric windows
air con doesnt work..even though have had an air-con service..it is the high temp sensor or something?
im worried they might wipe my remap
My One touch stopped working in my Mk3 - Try putting the window up but hold the button in the full "UP" position for several seconds.
That should reprogram the one-touch. Only takes a second to try out, might save on the warranty bill should they void it for the remap :p
[edit]
Also the indicator flash can be set up on VagCom I'm sure - Has it specifically stopped working?
[/edit]
ok will try it when im in car....
stop scaring me with the voiding business LOL....
so they can tell if the ECU has been flashed? they wouldn't reset it to stock would they?
Unless the faults are directly related to the ECU upgrade, Which they are not (By the sounds of things) they wont do anything.
They can't void your warranty because its been remapped and de-mapping your Ibiza is not something dealers/Mechanics will do
awesome....the 'one stop' windows work now
so only the wipers, air con and light when locking
got the air-con serviced as though this was the fault by they said it was a temp sensor on the air con unit..so that warrenty work
dealers cant see if your car has been mapped, but if there is a softwware up date for the car and they put it on, you have lost your map!
my car was boosting to about 23 and 24 psi before and is doing the same now after the warrenty work so touch wood its all ok!
anyone konw what a normal pd130 should be boosting too
definately didnt road test mine....left it with 72.1 miles on the trip
and picked it up with 72.3 miles...maybe a little spin...:)
