dajoco
I am enjoying our new Ateca 1.4 SE which we have now been running for about 6 weeks. We opted for the winter pack and the heated front seats have been appreciated in this cold snap. However, one of the features of the Winter Pack should be a wash water level indicator. I can see no sign of it and the manual does not seem to mention it (although the indexing in the manual leaves much to be desired). Please could anybody tell me where the wash level indicator is situated?
I can't say that I have seen the indicator but then I have never emptied the reserve, I do have the winter pack. The latest Ateca manual ATECA User Manual_11_17_EN.pdf page 48 shows the warning light
Level of windscreen washer
fluid too low.
››› page
153
Then seems to fizzle out about talking about the subject.
It might be lurking in the ErWin materiel or one of those features that's in the manual but not on the car. You would expect a sensor on the reservoir bottle. That you might find in the ErWin manuals although wasn't mentioned in the maintenance manual apart from top up.
Yes page 57 / 58 Ateca 2017 ➤
Electrical system - Edition 07.2016
The Erwin manuals you pay your money and download. Good resource. I gave a link on here.
I was on a ferry and was going to edit the link into the ErWin materiel
http://www.seatcupra.net/forums/showthread.php?t=438077
Text and there is a picture... text
2.3 Removing and installing windscreen
washer fluid level sender
Special tools and workshop equipment required
♦ Drip tray - VAS 6208-
Ateca 2017 ➤
♦ Lever - 3409-
Removing
– Turn off the ignition and all electricity consumers.
Vehicles without access and start authorisation system
– Remove ignition key, if fitted.
Vehicles with access and start authorisation system
Store the ignition key outside the vehicle to prevent the ignition
from being switched on unintentionally.
Continuation for all vehicles
– Place the vehicle on a lifting platform.
– Remove the left front wheel ⇒ Rep. gr. 44 ; Rims and Tyres .
– Remove the spoiler on the front left wheel well ⇒ Chassis -
external assembly work; Rep. gr. 66 ; Wheel well liner .
– Place the drip tray for fluids - VAS 6208- under the washer fluid
reservoir.
– Removing the front bumper lining ⇒ General body repairs,
exterior; Rep. gr. 63 ; Front bumper; removing and installing
the front bumper lining .
– Disconnect the electrical connector-2- from the sender for
washer fluid level -3-.
– Pull out sender for filling level-3- using the lever - 3409- from
the washer fluid reservoir -1-.
Installation
Installation is carried out in the reverse sequence; note the fol‐
lowing:
– Check the sealing lip between the sender for filling level -3-
and the washer fluid reservoir -1- for damages.
