I was on a ferry and was going to edit the link into the ErWin materiel
http://www.seatcupra.net/forums/showthread.php?t=438077
Text and there is a picture... text
2.3 Removing and installing windscreen
washer fluid level sender
Special tools and
workshop equipment required
♦ Drip tray - VAS 6208-
Ateca 2017 ➤
Electrical system - Edition 07.2016
♦ Lever - 3409-
Removing
– Turn off the ignition and all electricity consumers.
Vehicles without access and start authorisation system
– Remove ignition key, if fitted.
Vehicles with access and start authorisation system
Store the ignition key outside the vehicle to prevent the ignition
from being switched on unintentionally.
Continuation for all vehicles
– Place the vehicle on a lifting platform.
– Remove the left front wheel ⇒ Rep. gr. 44 ; Rims and Tyres .
– Remove the spoiler on the front left wheel well ⇒ Chassis -
external assembly work; Rep. gr. 66 ; Wheel well liner .
– Place the drip tray for fluids - VAS 6208- under the washer fluid
reservoir.
– Removing the front bumper lining ⇒ General body
repairs,
exterior; Rep. gr. 63 ; Front bumper; removing and installing
the front bumper lining .
– Disconnect the electrical connector-2- from the sender for
washer fluid level -3-.
– Pull out sender for filling level-3- using the lever - 3409- from
the washer fluid reservoir -1-.
Installation
Installation is carried out in the reverse sequence; note the fol‐
lowing:
– Check the sealing lip between the sender for filling level -3-
and the washer fluid reservoir -1- for damages.
