If in the recent weather, your windscreen washers havent been working properly i.e. you can hear the pump running, but nothings coming out - make sure theres fluid in/not a block of ice.
If after that it still isnt working, you need to do this;
Jack up and remove front left wheel
Remove 4 screws (star heads) 3 from inside the arch, and one further forward underneath where the wing comes under.
Pull plastic inner arch away (doesnt move too far) and you can see the pipes joining on to the pump and washer bottle.
Check if they're seated correctly, give them a good push together, and onto the tank, one side goes to the front, and one to the back washer.
And that should sort them out for you.
Sorry no pics, was a rushed job - but shouldnt take more than 10-20mins and saves a lengthy trip to the stealers.
Need any more info etc just pm me. If theres enough interest in sorting this, i'll take the wheel off again and get some photos up.
Cheers,
Matt.
Cheers,
Matt.
