wastegate problems
kennyrodgers84
kennyrodgers lcr
ok got a bailey dv30 dirt cheap and fitted it to my lcr.ever since i have done this the wastegate chatters every now and again.is this cause the bailey uses a progressive rate spring which might be a bit stiffer??before i fitted it i tried pushing the piston inside the dv up and it seems alot stiffer than the forge 007p with a yellow spring.
LiCkWiD
LiCkWiD EvOLuTiON
Nov 15, 2006
892
Essex
There is a common myth in the automotive world about so called "wastegate chatter", a noise created on lifting off the throttle in a turbocharged car. The sound is commonly described as a chipmunk or a rattlesnake and is often stated incorrectly as being a result of the turbo's wastegate closing.
The noise is in fact the air compressed by the turbo passing back through the compressor housing of the turbo after having hit the now closed throttle plate.
A blow-off valve (BOV) will usually eliminate this noise, but in some cases, i.e. where it doesn't open fast enough or is setup to only react to high boost, some chatter will remain.
The chatter noise is very noticeable on WRC Rally cars, where no BOV is allowed.
- Wikipedia on wastegate chatter/actuator flutter.
The chatter would be related to the air passing back through the housing. :S It could be caused, as you say, by a weak spring.. is it causing performance issues?
LiCkWiD
LiCkWiD EvOLuTiON
Nov 15, 2006
892
Essex
Well i don't mean to patronise you if you already know how dvs effect the operation of a turbo, but the idea is they purge the unused boost before it passes back through the turbo, slowing down the rotation.
When the turbo comes on boost, it forces a higher density of air into the chamber, yeh? It takes a while to generate this boost and when you ease off the throttle, the air has two choices.. without a dv, it flows back away from the throttle plate and back into the turbo. This has a reversing effect on the motion of the turbine.
Before this can happen, the dv releases the unused boost.
That said, DPJs answer is probably correct :S Can you try another dv on your tubo?
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
its actually the spring is too stiff, or like Dave said the pistons stuck, causing the air to not be vented and force its way back over the turbo blades,
not good.
kennyrodgers84
kennyrodgers lcr
thanks for the replies lads.yes i do know how they work,im a mechanic but its always good to pick the brains of others who might have had the same problem.took it off there now and it does seem a bit stiff at first wen u push it then it frees up.just a bit miffed as its brand new.have my old 007p back on
Mitchy
TTRS
Oct 12, 2004
2,310
I had same problem with the baileys DV30.
It was fine for 2 years then all of a sudden it started sticking. It would only do it for the first 5-10miles per day. When the car had warmed up, it would then work fine:shrug:
Changed it for the forge valve and back to normal now:)
You can clean the DV30 so may be worth cleaning and regreasing it.
kennyrodgers84
kennyrodgers lcr
yea funny enough it was at the start of journeys it gave bother.did u hear the wastegate chatter??took it apart at dinner time there and it full of this gluey ****,lol.cleaned it with brake cleaner,polished the inside with brasso and coated the piston in engine oil,seems 2 b fine now
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
dismantle the bailey and see if the top cap is riged.. worn ripply from o ring groove
if so its dead.
had the same on mine
