Clutch/flywheel
The flywheel design has changed over recent few years. They now operate a dual-mass system, which is ( basically) two flywheels, joined with springs. This has been done to smooth out the transition between disengaged and engaged.
When the clutch has not been used sympathetically, then the flywheel may well have incurred enough damage to mean that it should be replaced at the same time as the clutch.
In most modern cars the labour element required to replace the clutch is no insignificant. Remember the brake issue you talked about, they were past half way by the first service. If the first clutch replacement reveals that the flywheel is "over half way" then the replacement of the flywheel while you are in there seems prudent.
I have just sent an exeo back with 106k on the clock.
I am on my second Leon, the first ( 170 PD DPF ) I used to drive spiritedly, but with mechanical sympathy and it went back with 120k on the clock.
Neither had a new clutch.
As for going to the media, I doubt anyone would be interested ( or even surprised ) that a clutch and flywheel had worn out on a learner car, and ( I'm sorry to say) most would probably want to run a story on a learner car with an owner that allowed the brakes to go past the recommended wear limit.
As others have said, the onus is on you to maintain your car correctly.
Do you change the oil every 18000 miles ( or whatever the road going recommended interval is)
in your track car?
Or do you do it more often?
That is an informed decision you make about the state of your car because of your non-standard use of the car. You are a driving instructor and should make appropriate judgements on how to maintain it.
In 3 years of driving I think I made 2 emergency stops.
I'm guessing you have made many many more.
PS, I saw a learner panic and accelerate in to a freshly painted garage door the other week. Owner of door saw it all as she was stood washing the brushes at the kitchen sink looking out of the window. Makes you wonder why they are still allowed to use roundabouts.
in your track car?
