Water pump or head gasket broke?
platofan
218
Well it's due for change in a while so unless it starts causing overheating i'll probably save it for the cambelt change.
Seat dealer suggested the waterpump too. Said he's only seen 1 HG go on a tdi.
meltonlad
391
huntingdon
when mine went tits up both temp gauge and temp on climate (setting 51) both said 90. just keep on eye on it mate. but if i was you i think i would get the belt done sooner than later why leave it a few 100's miles and risk causing more damage ?
muddyboots
Still hanging around
Oct 16, 2002
5,739
My guess it's Ye Olde VAG water pump issue.
I had one go on my last Passat (PD130). While driving at lower speeds, everything was fine. You could see water circulating. But under prolonged engine load, coolant temp would shoot up, boil and piss out of the expansion cap over the bottle.
The plastic impeller had become loose on the water pump shaft, not completely loose though - it still turned enough to circulate a bit of water, but not enough to remove the heat generated under load.
And this was a fairly new pump, fitted at 120k miles during a cambelt change, as a precaution :D
Husbandofstinky
Out from the Wilderness
Nov 8, 2007
1,515
12
Temperate Regions
Stating the obvious but you do not want to cook the block, an early belt and pump sounds to be in order.
When was the last time the belt/pump changed?
I assume it'll be due in about 13k anyhow.
platofan
218
Service history says 70k it was done, a bit late there. It's on 107k now, but I noticed today i'm losing coolant.
Can't find a leak though!
meltonlad
391
huntingdon
when i got my car the service book said cambelt done only 7k before i got it but the water pump was not replaced... does the paper work say water pump ? or just cambelt kit ?
platofan
218
Surely should have said water pump as the cambelt kit is just a cambelt kit.
My temp is fine but i'm losing more coolant on motorway trips and might get it tested again.
Starting to annoy me!
meltonlad
391
huntingdon
mate if the stealers have said water pump and most of us have said the same then wht dont you get the pump replaced. if it dont say water pump on invoice when cambelt done then get it replaced before you do major damage.....the more you drive it the more damage you could do. just bite the bullet and get it done.......................
platofan
218
I think it's about I did mate, just thought it might be cheaper if I got the HG, water pump and belt done at the same time rather than just get the belt and pump done not for it to solve the problem.
Do you mind me asking what your symptoms were?
Viking
Insurance co's are crap.
May 19, 2007
2,317
Near Richmond, North Yorks
I still think...
Is there coolant circulating through the header bottle? If so then the water pump is working. This small stream of bubbles leads me to think that the head gasket is passing combustion gas (very high pressure) into the coolant waterways (relatively low pressure) and that's what is pressurising the coolant.
A failed water pump wouldn't pump coolant and a stream of bubbles round the system. The bubbles have to be coming from somewhere in the system, and I can't put my finger on anywhere else that it could be occurring.
muddyboots
Oct 16, 2002
5,739
Mine did...the impeller had just enough grip on the shaft to turn - it was slipping but still turned. Enough to pump water round at idle and keep the temps under control under light load. Constant load for a few minutes though, and it couldn't cope - resulting in boiling coolant pissing out of the header tank.
In other cases, I understand bits of the impeller break off, which would lead to a similarly reduced cooling capability.
Personally, if my car had already covered 47k on the current cambelt, I'd get the belt & pump done now, and see if that cures it.
Viking
May 19, 2007
2,317
Selective quoting there mate. What I said was
"A failed water pump wouldn't pump coolant and a stream of bubbles round the system."
Edit: The problem is the stream of bubbles in the coolant. That's what the failed water pump idea fails to explain.
muddyboots
Oct 16, 2002
5,739
I've fixed my quote :)
If the impellor was broken, with sharp edges, it could be cavitating and causing bubbles...:shrug:
Viking
May 19, 2007
2,317
Possible. Only one way to be sure really and that's take the bull by the horns.
Tell you what, I'll make a bet that I'm right about the head gasket and I'll be happy to lose it. You take a bet on the water pump and I hope you're correct. That would be the cheapest option. :D
muddyboots
Oct 16, 2002
5,739
:yes: And whatever the cause, the sooner the better before more terminal damage is caused.
How about this scenario: the water pump failed, causing a serious overheat, which then caused the head to warp and subsequent leakage through the head gasket :D
platofan
218
Should the head be ok seeing as the temp has never gone above 90 even on the motorway. I'm just experiencing loss of coolant on the m/way and pressuring up of the system.
Water pump seems ok, i see it pumping the coolant round. But really if i'm going to get the headgasket done then i'll be waning the belt and pump done to save on having to get it done again.
Knowing my luck though, i'll still have the problem after lol
