after lowering would i benefit from having my traking done also or spaing the wheels out
Yes...get it done. I didn't and the inside tread of the tires wore down very quickly. Two new tires = just under £300! Best to spend the £25 or whatever on getting the tracking done. Remember, after lowering, the OEM tracking specification will not be valid...I had to get the best 'guestimate' done ... seems to be ok so far.
Hi, not too sure if i have the right thread, i have a ibiza bocanegra, getting bored of the height of the car, any idea what springs i can buy, dont really want it dropped too low.
Cheers.
Its a little harsher than standard but handles and looks fantastic
Im running VWR springs with H&R front/rear ARBs and superpro poly bushes, and the ride quality is as good, if not better than stock, and the handling is absolutely sublime.
I was considering AST coilovers which are pretty much the only kits i have tried which are what i would call acceptable for road use as well as track, and have the pedigree as well, but in all honesty, its so good now, im not even going to bother. ill just be adding some Bilstein B8 dampers and thats it.
Hello guys. I am thinking to change the springs of the FR TDI for the H&R one's.
Do anybody know if they are softer/harder/same than the original one's? I feel OEM one's are hard enough although a bit more won't disapoint me.
What about the side skirts? I use wheel spacers (17mm in each wheel) and have installed side skirts. I am a bit worried about the -40mm in the rear.
I've got a set of KW V1 Inox-line coilies and would recommend them, very stiff but you get used to them, make the car handle well and gives the car a nice drop to whatever height you want.
Guys, I have a question about this, I have side skirts and wheel spacers and I am worried about dropping too much will make the wheel touch the skirt or the side of the car.
I thing 25/40 of H&R is too much at the back and TDI's aren't supposed to be highier at the back?
Are APEX -35mm good quality springs? And what about Weitec?
I think Eibach -2.5 are not dropping enough to notice it...
Any help =P ?
