Yesterday I had a downpipe fitted to my LCR 225. Everything was fine in that department and now the alignment is out badly which I knew would be the case before hand. But when I'm driving along and every now and again I will get like a grinding noise and the traction control light starts flashing because I think it thinks it is wheel spinning. I've noticed it only happens at slower speeds. I put my foot down slightly just to see if it does and I get just the usual wheel spin as would be expected. But as I slow down then it makes that noise and then sometimes I also get a whirring noise (like you would get from a motor of some sort) then after about 5 seconds it's back to normal.
Now my question is, is this to do with the alignment being out badly or could it be something else?
