well, i havnt really had this motor for very long.
but there was a flat spot, also seemed have power loss
well, to day i found out why.
1) this was simple, wrong plugs. so put a set of ngk platinum in
2) 2 of the plugs wasnt even in proper??
3) becouse of the plugs not in proper, the coil packs wasnt even in proper
one of the water hoses were loose, dodgy spring clip. then the oil leval was lowish.
the guy i got this motor off, said he was a macanic, and builds cars???
so far i've spent quite abit to get the car right, once the right bushes turn up. i'll be fitting the rear axle, as that was bent very slightly.
had the wrong size tyres on, the front discs were warped. the track rods had play both ends. the cd changer was naff. and to top it all, the fob dont properly work
oh, and the bracket on the centre cection has come off, so rattles.
so far, every thing is about done. bar 3 things, the brack on the exhaust, the rear axle & the fob (that will be last)
so much for a good macanic hay....
wonder if the guy was gegisted on here???
