what is best chipping or remapping?
Big_A_Cupra20vt
184
margate
what is best chipping or remapping? i have a standard cupra 20vt and just wondered what is best way to get the power up. how much bhp would i gain from either of these? and how much am i looking at paying?
karl.w
methanol junkie
Oct 26, 2005
606
if chipping is done right then there is no reason why it should cause a problem!!
but remapping is always be the better option.
Big_A_Cupra20vt
184
margate
what would i gain more bhp with a chip or re-map? is the difference in price between a chip and re-map? also would i need to upgrade anything else? am i right that the engine in a cupra is the same as a 220bhp engine in an audi tt? or is that rubbish?
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
a re-map is the normal sort of thing to do...dont know anyone that chips it. well its the same base engine, just the audi tt engine has different compression, injectors, maf, turbo, and things like that
slimjimvw
Newbie
Jul 28, 2006
114
Exeter , Devon
You want a Re-map mate , no opening of your ECU involed , they simply plug into your serial port and flash the ECU with new software , job done. You don't have to upgrade anything else if you go for a generic type map like Revo.
Not really , different internals , compression ratio and turbo ;)
Do a search on Revo mate , loads of info on here .
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
THe problem is you don't know if it is any good or not - or if the person doing it is untrained (but has done loads)
Bogwoppit
1,085
Lincs
Depends where you go, approximate prices:
Forge 007 diverter valve £95,
couple of Jubilee clips for new diverter valve £2,
Green panel filter £35-40.
remap £375
You could fit the panel filter and diverter valve yourself, 30 mins tops.
Big_A_Cupra20vt
184
margate
not a bad bit of power i think ill look into having it done, i think it will be fun then i can piss all over my mates 206 gti 180 ha ha ha
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Its not all about bhp, id say torque is more what you want to 'piss' over your mates... with my mods not really proformance inhancing i made 230lbs ft from revo ;)
David.
