What is Engine Slack?
KingSala
Kingsala
Oct 20, 2007
82
Liverpool
Hi every1, I was gettin me cambelt changed today and also to investigate this tapping noise comming from the top half of the engine but i got a call before to say its not the tappets its got or it is 'ENGINE SLACK'.
Could any bright person :p out there tell me what engine slack is?:shrug:
Thanks.
Roberto:redface:
KingSala
Kingsala
Oct 20, 2007
82
Liverpool
thanks for the reply bud, I worded that wrong! its not engine slack its 'ENGINE SLAP' lol sorry for the confusion but will this tappin av got from my engine cause any harm in the long term? or should i investigate it further ? thanks again :clap:
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
no way your engine has piston slap unless who ever as owned it has ragged it from cold.. mine has done 120k miles and its a bit rought around the edges but runs fine!
Feb 25, 2007
1,068
cheshire
you have piston slap, tapping noise from the bottom end, its very commen in the 1.4 8v, its when the piston rings have worn so the pistons have alot more movement in the bore causing a slapping noise.
repair, new piston rings! expensive and big job, not worth doin really it will still run fine just noisey
KingSala
Kingsala
Oct 20, 2007
82
Liverpool
Thanks dudes so, this wont in any way harm my baby beeza :) lol cus i lv it and spend loads on it and dnt want it to die :p.
Thanks again for your reply, this sites graet ! :funk:
:clap:
KingSala
Kingsala
Oct 20, 2007
82
Liverpool
no its got plenty of miles left mate
gdgd lol:) would changin then oil help and puttin some engine treatment in ? its gets its oil and filter changes every 2 months or should i nt bother, is 162.5 quid gd for gettin the timin belt and tensioners and water pump a gd price?
thanks:D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
I'd go with piston slap, when my work were a main dealer we replaced several bottom ends due to it
did a 2000 mile AKK motor cos of it - ordered a replacement short motor and fitted to find it was even worse !!!
found culprit though - new replacement bottom end had been supplied all fitted up crank rods pistons all in place - but no rings ??? :lol::lol:
roly
midnightmotors.net
Jan 2, 2002
1,883
Midnight Motors Workshop
Sounds familiar, or you get the usual back order on something that holds the whole job up :rolleyes:
