Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Forget that...it will suck more go go juice than a bangkok ladyboy...
Needs to be mapped to run a 4bar FPR.
TIP next..and if you haven't already...Air filter.
Yep..£220 there abouts will get you a fmic..for a LCR..
I take it your is??
Yeh atmos ain't good on the 1.8t vags.
Tis true,if you want mpg...best go over to derv!
That's not what a LCR is all about!
I have a HKS knockoff which works quite well, but in the end it keeps throwing me in limp mode.
Also does anyone know about the pipe work for the mani to the fmic? The guide doesn't give to much info on it and it looks like it will fall short so I'm only guessing that a 45 degree hose and alloy pipe will connect it up to the other hoses to complete the pipe work?
