bkingb
178
kent
what upgrades and mods have you done and why? and are there any mods you would like to share that has made an improvement?
i.e i recently upgraded the seat leon seats as the standard ones were a not very supportive.
stage 1 remap on the seat leon 1.8t ko3s was a big yes when it comes to ugrade it was bang for buck upgrade but i recommend that you install performance parts before you remap ca to get the most out of the mods.
HID make the car look very good is defo upgrade
Standard exhaust was not very good so i changed it to an milltek cat back system defo recommend with the quality and sounds not to chavy
have you got anything to share?
:D
well worth doing the n249/n112 bypass mod. cost me a total of £4.49 (2m of silicone tube-to be safe)
gets rid of any unwanted dumping and increases acceleration.
induction kit pretty good, gives a bit more noises and improved throttle response, can be done cheaply too.
better brakes worth doing if you got more power, im using a set of grooved discs alot betetr than standard.
list is endless really depends on your budget and needs/wants of the car
possible to swap brake from cupra r as they have brembo brakes at front
also using v power 99 octane and or tesco momentum 99 helps with performance
my homemade electric freshness system, nothing worse then your mates fart stuck in the car with you, or the smell of cow **** on a country side drive lol
note, the spray nozzle is now mounted in the venting system so only the aroma comes through and no wet spray
