what mods???
seatcupra2001
150
Andover,hampshire
hi im a newbie i got a 2000 seat leon cupra 1.8t 20v which has covered 73000 miles with full service history what sort of mods can i start off with that a cheap???? also can some tell a bit more about my car engine whise? thanks :D
Fabia rear wiper - <£20
Golf Mk4 Aero front wipers - £50-70
C2 or Civic Type R Ariel - £10
Green Cotton pannel air filter - Smoothed/drilled air box - £40-50 filter, free smooth and drill
Forge 007p Dump valve - £70 i believe
Coil overs - £300-500
AmD stage 1 remap - £300
That'll do donkey.... that'll do
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
is it a 20 v turbo mate, you posted 1.8 20v?
if a turbo, stage 1 map goes to around 215 bhp
add a dp and sport cat and stage 2 map then your looking at 225
edit, seen 1.8t now
james walker
May 24, 2007
5,121
retford notts
right, what id do.... in this order aswell
handling first
decent spring and damper setup £200+
ths dogbone mount £50
rear arb whiteline £135
new top mounts £30
tt wishbone bushes £20
ths engine mounts £100+
4 wheel alignment after £50
power
forge 007p
fmic £200 upwards
high flow downpipe and sports cat £450
silicon t.i.p £80 ths
induction kit or panel filter £30-£100
replace as many chocolate textured oem pipes in the bay as possible with silicone....
then stage 2 map strait after all this £300
after that id go braking with a custom 911 carrera porsche setup circa £500
then lsd £1000
once youve spent all your cash on these then maybe look at fabia wipers and little mods, hids etc etc
good luck and happy saving
james walker
May 24, 2007
5,121
retford notts
can i jusk ask, why do you want coil covers.... and have you a link to them?
what would you like to achive from your car mate?
lol im blind today.... coilovers.... though it said coil covers!!!! tail.
id stay away form coilovers for a normal street cat tbh mate, especially the budget ones from ebay.
what id do is do the other handling mods forst and see if you really need to lower the car
Mar 29, 2007
1,207
Berkshire
I'd also add upper and lower front strut braces to Jamie Walker's list of handling mods - and replacing the 'pancake' pipe that you have in the LC too.
Edit: Can't go wrong with some good tyres too! :)
james walker
May 24, 2007
5,121
retford notts
yup, wouldnt really go for that mod just yet mate, not a real noticeable one that.
much better saving cash and getting a fmic.
youd be better deciding a route to go down with your car then get them mods done first, to see most gains
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
You can get those pancake pipe replacements along with the other pipe that goes to the inlet manifold for about £25 from Ebay US, even with postage there under £50 for both :)
