deanomx206
to run standard cupra 16" alloys on my car but its low on coilovers?
heard ill need spacers or itll scrub?
do i need them front or rear and what size?
Pretty sure you will find this info if you search mate! But i'll help anyway! :p
Depending on how low you are they should be ok without spacers, most on here use 20mm on the rear and some have 5mm on the front.
I'm sure some will confirm if this is correct or not but pretty sure this will be ok.
I have 20mm on rear
had to put 3mm on fronts when i did brembo conversion
