Apr 22, 2010
494
Leicester
hi, managed to lose a wheel bolt grrr :( anyone know what size i need as a replacement? and does it make a dif as im using spacers? will it be the same bolt but longer?
this is for a lcr with bbs ch reps
spacers make a difference
standard length in metric is 27.5 mm + spacer thickness
Does it have 6+ full turns and is it tapered? both sorts will fit but you need the correct angle on the bolt head of it will come loose.
hmm it looked exactly the same as the ones already in there, and the code on the top of them was the same. b13 10.9 or something like that?
