As has been said above, you do not have to re-calibrate your speedo, provided you select the correct sized tyres.
Below is a chart showing the difference on speedo reeding between an eighteen inch wheel and a sixteen inch wheel.
As you can see the difference is negligible, at 90mph an error of 0.7mph. The tyres differ only by 0.2mm on the overall diameter, normal tyre wear over the life of the tyre would give you more than that.
