I am in the process of fitting a dash cam, and have bought the power cable which goes straight to the fuse box. I have installed the cables, however the negative cable is supposed to be connected/screwed under a screw on the body of the car. The easiest one to use appears to be the one on the front passenger door.
So, can someone tell me what screw piece I need for the circled screw? I'm guessing it's a torx or spline of some sort?
EDIT: So a response below suggests the door is a bad option. There is a torx screw I can see behind the glovebox- could I connect it to that?
