Which coilpack!?
Undezcupra
Francis Seat
Dec 21, 2005
383
Leicestershire
A coilpack has gone on my beeza so i phoned euro car parts and orderd a new one, it came today and iv fitted it and all is fine, however..... The coilpack is different to all the other 3 i think its the one off the tt and a3 etcetc it still fits amd works it just requires two screws in those two holes which are on the rocker cover to seal it in place, i just wonderd weather it would be a good idea to buy another 3 to mach? as thats the only coilpack they had on there system for a 20vt engine???
:shrug:
help please guys..........
kieran_cupra
Yellow n Black works!!!!
Apr 15, 2006
403
Nottingham
. i had this from euro. they have discontinued the old ones. luckily my mate works for euro and gets me proper vag ones for the same price
karl.w
methanol junkie
Oct 26, 2005
606
i had this problem with ECP the coilpack they list for the ibiza is the wrong one
but i managed to get the correct one from them.
The correct part number is
413 44 0480 made by beru
T7ODD
I quoted the proper VAG part number to GSF, confirmed the engine code of my car and it was the correct one.
The fault light will go out by itself, although the fault will remain logged on the ecu. If you like to keep ontop of your registered faults then it's best to get it cleared with VAG-COM. Just handy if you're trying to get to the bottom of a current issue and it's flagging up a fault from months ago which has since been resolved.
L.R.C.
234
Because i dont remember....
does our rocker cover has holes to screw the TT coil packs?? (Are all TT coil the same??)
WeeJase
pert
Jun 2, 2001
8,595
how much are they at ECP? my mates octy is in the dealers with one(diagnosed by me 140 miles away :D )i siad check on price before buying.
are they doing them FOC at dealers these days?
kittyk8e
If you haven't got VAG COM by the way you can clear the fault by disconnecting the battery for approximately 10minutes.
Whilst your there it wouldn't harm to do a throttle body alignment, to do this when the battery is reconnected turn the ignition on (DON'T START ENGINE) and then you will hear a whining noise coming from the throttle body once the noise has stopped it will be re-aligned (DON'T START THE CAR WHILST DOING THIS).:)
