It does need quite a lot of trimming, mine scratched the glass quite badley because i didn't trim it before i put it on. The best bet is to compare it to your standard one and only put it on when the cap matches as that's the main problem area!
what exactly needs trimming?
The cap and the bottom of the arm needs a bit taken off due to the different rear window designs on the polo compared to the Ibiza as it will scratch the glass if it's left !
Any chance you could pop up a picture or two so I can see what you did. I'm definitely getting that one and before I get it, I would just like to see what it ends up looking like.
Does it wipe perfectly? No patches unwiped and a perfect semi circle? Cheers Veyron, Tom.
my polo wiper didn't need trimming think it depends how far they poked out the spindle
Yes it works fine mate, much better than the standard arm or even the facelift one because it comes with an aero blade, it missed a patch in the middle at first until it was trimmed then it fit perfectly! Sorry i didn't take any poics wbhilst i was modifying it
