Addo
I've mislayed my owners manual and i need to know which relay is which?
what is 100?
what is 19?
what is 53
what is 405?
what is 100?
what is 167?
Addo said:
what is 100?
what is 19?
what is 53
what is 405?
what is 100?
what is 167?
a quick scan in etka
100 - one is a std relay / other is secondary air valve
19 - int wash wipe
53 - horn
405 - pass
if it helps any grab the part number off em and ill double double check
19 - int wash wipe
53 - horn
405 - pass
Flapper i tried swapping all the relays and no change. thankyou for your help, but i need one more favour. can you check on your etka parts catoluge and tell me if the wiring loom that connects to the coilbacks and N valves ect... can be bought as a small section of the loom. I'm hoping i can buy a small part of the loom and not the whole loom.
all the seperate connectors and pins can be purchased seperately anyway m8
may take a couple of days though usually
easy way to id them is to take the number off the old one and go from there
i'll check on looms anyway just in case its a simple cheap plugin one
Casper said:
167- fuel pump relay
Thanks you were right 167 is the fuel relay unfortunatly i swapped it with mike and no differents. i'll have to check some of my wire's as they were close to the turbo and i've installed my new pump. the annoying thing is im driving around in safe mode. 8psi :cry: i want my 330bhp back :lol:
