When he showed me i thought he had the standard exhaust on! Exactly the same as stock when on idle/low speeds, then gets louder the harder you put your foot down![]()
thats how i like my exhausts... defiantly a win by sounds of it
For guys having this issue with the engine management light flashing up under hard acceleration, i mentioned this in the VAGOC thread that a fair few guys on here have had the light flash up once or twice, and that some guys thought it might be the injectors.
Another guy has posted up saying to regap the spark plugs to 0.7mm, although he had a misfire, so maybe not related.
Your right mardon its so twitchy and Chris I am at Santa pod next week for gti spring fest but that's it at the moment I need coillies first before any track workthink I might leave my interior out for a bit lol I love the noise and the speed is insane
I think it would need more than plugs. Surly upgraded injectors as well?
245hp+ is quite attainable from the stock engine with a properly designed exhaust system... the reason we don't do it is because it will break the clutch set-up... we will be holding off until a suitable upgrade to the DSG system is developed.
IMO, Chris has the highest available performance within the safe threshold of the transmission![]()
REVO have held back their stage 2 power as there was to much heat build up for the stock IC to cope.
Did you not find the same issues?
And how deep are your pockets
Absolutely not, air intake temps were ideal never exceeding 27degrees... even under prolonged full load. I suspect this is due to the unique design of Chris's downpipe which allows the turbo to run substantially cooler than stock.
Naturally an intercooler would be helpful but just how much power do you wantAnd how deep are your pockets
a 'unique' design. Your not exactly flooded with space for extravagant options. What does this entail over say a normal aftermarket exhaust? All performance downpipes with alarger bore, removal of the precat and a more efficient 2nd cat will lower the exhaust gas temps much lower than stock.
Its also great quoting what the IAT was but if you dont mention the ambient temp it means nothing.
The peak intake air temp is absolutely what is important as far as turbo efficiency is concerned ... over 30 degree c is a no no...regardless of the outside air temperature. It's custom made, you don't get much more unique than thatPerhaps Chris has a picture of where it joins the turbo and you can decide for yourself.
Can I just ask where in britian you would find an ambient temperature of more than 30 though for this to be a problem.
he's got a point thereCan I just ask where in britian you would find an ambient temperature of more than 30 though for this to be a problem.
