Who knows their relay numbers?
BusIt
Hi,
First post, hope someone can help...
Does anyone have a wiring diagram or list of what fuse/relay does what on a Mk1 Toledo? I have a battery drain on mine, not sure if its related but relay 18 gets fairly hot after a run, I would like to know what it does first before I pull it!
chuckie888
From the Vento Haynes manual .. relay 16 (mine has number 18 stamped on it) is the top of 2 rows, 3rd from right = 'X' contact relief relay. Dunno what it does though!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
they are laid out like this
19 20 21 22 23 24
13 14 15 16 17 18
1 2 3 4 5 6
7 8 9 10 11 12
1) aircon relay
2) -
3) engine control relay (petrol) / Oxygen sensor relay / EGR system relay TDI
4) ignition aux circuits relay
5) -
6) indicator/hazards relay
7) headlamp washer pump relay
8) windscreen wiper intermittent relay
9) -
10) fog lamp relay
11) horn relay (twin only)
12) fuel pump relay petrol / glow plug relay tdi
13) aircon relay tdi / engine coolant blower motor timer petrol
14) lights on warning module /
15) lighting circuit control relay
16) fuse (20a) electric windows
17) ABS pump relay
18) ABS relay
19) aircon condenser blower motor relay
20) seat heater control module (osf)
21) seat heater control module (nsf)
22) transmission system relay - auto / intake manifold pre heater relay 1.6/1.8
23) idle speed control 1.6/1.8 / fuse 30A ABS pump
24) idel speed control 1.6/1.8 / fuse 30A ABS
those are off autodata if it helps ??
