i ordered these as per a previous post and they wouldn't go in the slot
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
those ones wont work and aren't the same as your ones![]()
i ordered these as per a previous post and they wouldn't go in the slot![]()
They are different the ones you have are higher resistance to the ones they are sending now friends ones have less resistors than yoursWell when i click on that link it says 'You bought this item'
I have 4 LED bulbs in my sidelights and the work a treat, no errors.
i purchased the same set as above and have canbus errors, just for info, its 2.0tdi fr
i added an extra resistor to my mates in the blank space now and it should remove the error codes hopefully.
Where did you get the resistors from for the LEDs? mine should be coming through tomorrow and just wondering incase mine go wrong![]()
I doubt there is any difference, perhaps you need to push a little harder, anyway they work in my car so go figure....![]()
