With the aeb block being fitted longitudinal to cars and the leon being transverse, Will it still fit if I use the mounts from the bam block and just swap them over.
Also will the crank be the same from the aeb engine as the bam engine, I'm going to swap out the forged pistons from the bam engine and buy new forged rods and rings and put in the aeb if I can use the aeb that is
Its just that the aeb engine is a lot cheaper than all the rest and if I'm swapping out most of the guts then it will be worth it and I could probably get started on it this weekend instead of waiting much longer.
It's just the mounts and the crank I'm not sure about.
