Willwoods
Nov 2, 2004
9,335
South Wales
I have these brakes and im sure theyre 94mm as well. Rally Design will make you hoses up for about 30 quid delivered btw.
Get the DS2500's from Bill as well for them, theyre about 100 and something quid when i had them, i made a thread in his section about them with the p/n needed.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
94mm centres is the measurement, which I have fo rmy brembo brackets. its not guessed.
cheers phil btw
Cupra Gsy
200
When you get willwoods etc are all the calipers the same and just the brackets different as i have a set of 4 pot willwoods off my old civic and if i can make them fit with different brackets i might as well
Chez
151
Edinburgh
I have a set of brackets which i bought off a forum member a while ago which suit Willwood Dynalite calipers and have the 94mm mounting holes.
They come complete with bolts and spacers.
I ended up buying a set of Brembos from Bill @ Badger5 so never used them.
If anyone is interested in buying them let me know, i had them in the for sale section a while ago but no takers.
Jan 8, 2007
2,958
Wiltshire
Just to add, the HiSpec R114-4 calipers fit behind standard Cupra alloys with ~3mm clearance. I've fitted a 310 x28mm 2-piece disk radial mount 4-pot kit using a kit for a MK2 Golf GTI which use the same hubs, just need longer braided lines which they can supply. Not a cheap kit but it's another option.
