Wind Deflectors - Anti-Trap
Jib
496
31
Doncaster, South Yorks
Hoping someone has a quick fix for this.
Bought myself some Heko wind deflectos which have appeared to fit just fine, however now the anti-trap is kicking in and preventing the window from closing. Has anyone else had this issue before?
Thanks in advance.
MrJohn91
136
64
www.facebook.com
Thanks in advance.
If I remember rightly you've to do it little by little, quick clicks of the switch to get it all the way up. Once it's up and settles it'll be fine.
Sent from my CLT-L09 using Tapatalk
martin j.
1,997
894
Fife
Once you get the window up using the above method, or a helping hand on each side of the glass, some wind deflector makers recommend leaving the windows up 24 hours to compress the seals and leave a bigger space for the glass to rise into preventing the anti pinch operating, cause a quart won’t fit in a pint pot.
ray
590
191
Same as above, to get mine up I just pulled the deflector out from the window until they went right up and totally fine ever since.
