Ian C
9
Bolton, UK
Hi,
New 2019 Leon ST.
When locking with windows down, holding the lock button closed all windows.
When unlocking, holding the unlock button all windows would open.
Now they don't?
I've checked in vehicle settings and all settings say they should. These haven't changed.
Any suggestions?
I used to have this issue on my mk2, would reset it by getting in the car and putting all the windows down and holding down for a few seconds, then doing the same going up.
I'll go and try that now. Thanks Ray.
No joy unfortunately.
Also notice the one touch close works on the passenger side but not on drivers door?
It seems to be a reset issue.
Did you fully open one window and hold the button down for 5-10 seconds then fully close the window and hold the button fully up for 5-10 seconds? You need to do this for each window in turn. This should reset the windows and allow them to operate via the key (opening and closing) as well as one touch for each window.
Hi Maypack
Thanks, I tried that but was still all the same.
Did a Full Factory reset on the settings via info screen....now all is fine again.
Thanks for your replies guys.
Reactions: LouG
Hi Maypack
Maybe you had accidentally un-ticked the setting to open/ close via long press on remote - easily done when scrolling through settings without realising!
