Feb 15, 2026
Hi all I am new to this forum.
I have a 2018 seat cupra 300 and when you lock the car the mirrors are meant to fold in automatically mine are not. I know you can keep hold of the lock button on key fob but like I said mine should fold automatically when you lock the car. I have tried to use my Autel scanner to try resit but couldn't find anything to do with mirrors.
Any help or advice would be fantastic
Not familiar with Autel but I can give you the steps to do it using OBD11. It should be similar in other configuration-capable diagnostics devices.
Go to the following setting:
Control units -> 09-Central Electrics -> Adaptation -> Spiegelverstellung -> Funk Spiegelanklappung Modus
The current value of this setting is most likely "by convenience operation..." in your car.
Change it to "by look command..." (It is meant to say 'lock', not 'look')
Write the change to control unit.
This should give you the folding mode you want.
Regards,
Serdar
Are all your windows working 'one-touch'? ie. one touch and they go up/down. If not, for some reason the mirrors won't fold in when you long press the key fob. You can try calibrating the windows - wind them all down (one at a time obviously!) hold the button for about 3 seconds then wind them back up and hold for 3 seconds once up. After that the one touch window feature should start working then the folding mirrors should start working. Yes, it's a stupid system and the Seat/VAG engineer that thought that up should be thoroughly ashamed of themselves.
Reactions: nd-photo.nl
