Karmacarzi
Anybody installed an amplified set of components in the front doors of their Mk2 Ibiza / Cordoba?
How did you get on threading new wires in to the doors / wiring plug and harness. I've got all the carpets and sound deadening up at the moment and I don't want to cut into the factory speaker loom if I can aviod it, so i was going to dis connect that all together, but running new wires into the doors seems impossible thanks to the plug in connector block on the A-pillar. I'm guessing it's possible to remove the dash side A-pillar connector and run the new wires from my amp (in the boot) to the existing plug in white terminal thing. Have i missed something here, or does this sound about right?
Cheers peeps
Cheers peeps
