First of all mate you havnt left your instrument cluster on dim have you ? thats the little wheel you can adjust to make all dash lights brighter and dimmer ?
Well every gauge i have done has only ever had 2 wires, live and earth and to light them up i put live wire in pin 6 and earth wire in pin 1 (I THINK)
guessing with your gauge and from what ou have said it has other wires to read oil etc.
It should defo work for you mate its just a question of working out which of the wires are live and earth to make the gauge light up. Should be easy to work out, on mine one wire came of the bulb holder (red wire, live) and the other just below the bulb holder (black, earth) i did only have 2 wires though.
Finally be sure your wiring them into the dimmer switch and not your headlight switch as i made that easy mistake the first time i cameto do it !. Dimmer switch is small and rectangler with only around 6 wires going into it if that. Headlight switch is a lot bigger and has alot more wires going into it and is straight in front of your face when you take your driver side panel of coverig the fuses.
