Cheers Adam, I really appreciate the time you've taken over this, and I reckon that would make a great addition to the guide on Icecavern, which can be a little vague.
What's the alternative to doing this? To me that sounds pretty complicated, and I'm sure there must be a simpler way of getting a remote wire. If I were to do it the proper way, do you know how I'd get an RCA/remote connection without losing the air con?
I got right up to the stage where I was ready to feed the wire to the amp, having connected the power and the RCA lead, but my main concerns are still these:
Also, when you did it, how did you connect the RCA leads? As you don't seem to mention routing them at the same time as the remote/power.
Thanks for your offer of help, but I live right up north in Cheshire, so I think it's a bit far for you to come. I'm really determined to do this myself, and I think bar the problems I've mentioned, it's not beyond me.
If anyone can explain this RCA business I'd be greatly indebted to you.
find a fuse that is 0V when the ignition is off and when the ignition is on goes to 12v.
i put a small spade connector in the end of the fuse and taped it in there so it would not move. from here i then wired it to where the power cable was.
Firstly, I'm not sure what to do about the remote/RCA cables as the mini ISO/RCA adaptor that I have will only go into the HU if I take something else out, and I think that something else is the air con, which I don't want to sacrifice.
Secondly, the remote wire that came with my amp wiring kit has a really strange end to it, which won't connect to the remote part of the RCA adaptor, or anything else for that matter. Either it's broken, or wrong.
