Would these coilovers fit a mk3 1.4.
Ethan040
60
Nottingham
Hi on the ad for these coilovers it says there for a 6k which is the mk3 is it not? but in the ad it says there for 1992 - 1998 models would they fit my mk3 1.4?
Also is the the polo 6n or 6n2 coilovers that can be fitted to a mk3 ibiza?
:doh:
Polo suspension - no doesn't fit.
92-98 suspension wont fit a car made from 99-02...
Look for the 6k2's. Sounds like you're looking at the coilovers on ebay. By the way I would suggest that you don't, or at least look into different options first (searching here) before buying them.
I had some on my 1.6 and hated every minute of driving the car with them on :rolleyes:
Ethan040
60
Nottingham
How come on the faq section on here it says Mk3 Ibiza FAQ's (6K) 2000-2002 and not 6k2?
Ive done alot of searching on here about springs and coilovers and spoke to antnee who uses the ebay coilovers and he says there fine when fitted correctly.
Also i though polo 6n suspension might fit with different top mounts as polo 6n suspension fits a mk2 ibiza and i thought a mk3 had pretty much the same shell as a mk2?
ndbrgr
THFC
Jul 21, 2008
1,023
Kent
If you look beneath that is says 6k facelift, which is 6k2.
I've read somewhere about different top mounts, but it's probably best to buy a kit thats designed for the car your putting it on.
Yes they will fit with different top mounts, but why bother when the proper kit is the same price..? Well at least it used to be!
Ethan040
60
Nottingham
The mk2 ibiza coilover kit is only £180 where the 6k2 kit is £280 there both the same cheapo coilovers so i just wanted to know if the cheaper ones fitted.
Do the mk2 coilovers fit with mk3 top mounts or is it just 6n polo suspension that fit the mk2?
