Yellow warning light urgent help!
RS6
Nov 24, 2009
1,110
Yellow warning light popped on!
Holy crap whats this? its low oil light checked the oil level all seems fine put some more in so its slighty over went out for a drive light is still on?
help!
cw1986
faulty sensor mate , its gotta b ! , u can usually clean the prongs but to replace it wnt bust the bank, prob 30 quid, ull find that the cold weather messes things up mate , this winter has just been to cold!
Henjo24
my engine management light came on yesterday morning! Hate seeing those lights pop up. I blamed my g/f she drove my LCR in the day and obviously cant drive it properly cuz she is a **** driver.
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
think its the oil level sensor, cause oil pick up or oil pump block normally follows by a red oil light flashing with 3 beeps . had that issue before
RS6
Nov 24, 2009
1,110
Yeah read the manual lee! dug it out last night, was like low oil? wtf can't be and got a copy of your pdf now very handy i seem to think its a sensor issue as all seem fines more £'s
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
don't want to jinx it but i strongly think its the oil level sensor fitted in the bottom of the sump ,
RS6
Nov 24, 2009
1,110
yeah getting a new sensor wed hopefully and a service!
more £'s to spend just before a remap :(
ab1702_123
93
Have you sorted this I would be interested to hear the outcome as I have the exact same prob, got a new sump as old one had a rounded off plug so now oil is to top Mark but stil a flashin yellow oil light every time I start up.
RS6
Nov 24, 2009
1,110
Yes sorted it
The oil level sensor was playing up just a constant yellow light pretty sure the cold temperatures outside can effect it btw if not that then:
if the oil level is fine then don't worry the fix for this is to disconnect the battery for 10mins and reconnect it thats the negative cable iirc
the light will then go out, had mine looked at with VAGCOM at the garage no error codes what so ever, just had a service done, oil change filter etc so hopefully thats the end of the problem, they didn't change the sensor as no fault code, so it will be fine to drive
the light is supposed to go out if low on the oil, when you open the bonnet top it up and close it, thats supposed to reset it, but more often than not it doesn't work disconnect the battery and all will be fine, as long as its not the red oil pressure light if you see that don't drive it get it towed to a garage for investigation
ab1702_123
93
I think it must be the sensor then because iv had battery off for about 2 hour and the light came bk on when started up again, have disconnected the bonnet sensor like u mentioned and still didn't cure it and the oil level is fine so pointing to the sensor me thinks, will have to go garage though as don't have vag com, the car is fine just doin my head in that the light flashes about 4 times every time I turn ignition on. Ps how did it cost if u don't mInd and did u do it urself? Cheers
RS6
Nov 24, 2009
1,110
yeah yours sounds like it needs a new sensor then,
if theres an error code vagcom will confirm the faulty sensor get it checked out
Joe_Cupra-R
I have the yellow flashing oil symbol when you turn the ignition on, had it scanned and it showed up - intermittent oil sensor, worth checking the wiring on the sensor, if that's ok new sensor, don't think they're too expensive.
rk696
683
West Yorkshire
PEOPLE PLEASE PLEASE PLEASE LISTEN TO YOUR CAR!!!!! :scary: :scary:
This is a big problem with the 1.8T engine, and has killed a few engines over on Briskoda.net. The yellow warning may be low oil pressure (It's red on the octavia). DO NOT DRIVE WITH IT ON!!! The oil strainer will be blocked, and serious engine/turbo damage will result, if it hasn't already. It can happen at any time, no matter what the service history.
Have a read here, it's such a problem, it's about to be made a sticky.
http://briskoda.net/forums/topic/187391-all-octy-1-owners-please-read-this/
There's a guide on page 3 how to change it.
You can tell if this is the problem as the oil level will be OK, but the light will stay on. Chances are it is NOT a sensor. They rarely fail.
Don't put this off, as oil starvation is mega expensive!!!!
ab1702_123
93
These are seat mate not skoda, the yellow light means low oil and the red light is when you have low pressure which is normally the blocked pick up, if someone has done a scan and it's showing a faulty sensor then I'd say it's a sensor myself unless vag com is wrong ?
rk696
683
West Yorkshire
Same engine though :thumbup:, so Seat's are not immune to the probelm. Skodas flash red for low oil pressure and yellow for oil level, and it wouild make sense that that theme followed across the VAG stable, but as we know that isn't always the case.
Still worth checking though, as if it goes, big bill time! Do it while you are changing the oil level sensor.
ab1702_123
93
Yes def wil check it, seems the lights are the same then cos yellow is low level(which is what we have) and like u said red is pressure, there is quite alot of threads on here which support what u said aswell about it getting blocked with gunk and the red light light coming on which like u sed is bad news so is obviously a common vag prob like other things.
Any idea if this blockage prob effects diesels as bad as the petrols get it as I'm in a diesel 150?
rk696
683
West Yorkshire
I'm not sure TBH, I think it's mainly the 1.8T which is affected. The 1.8T turbo runs a lot hotter than the diesels, so that can't help.
I've looked on the net, and the pickup on the 1.9 diesel looms very similar to the 1.8T, so probably worth having a look.
csd_19
2,280
28
Angus / Edinburgh
If you turn the ignition on (but not start the engine) does it still flash the yellow light? Because that to me would indicate a faulty sensor/wiring instead.
