Clutch upgrade options
g60stu
426
317
Reading
I'm getting clutch and flywheel changed tomorrow. I got mine from carpartsforless (euro car parts). LUK DMF around £250 and clutch/pressureplate/CSC for about £129. That was for a LCR. Seemed like good prices to me considering the eye watering price of a DMF from SEAT.
Reactions: Rich.T
Connor H
1,015
498
Essex
brah that is cheap for both the kit and the FW, cheapest i saw a luk dmf with sale was 305!
You mind linking me the kit you bought? i think im going to get a kit and switch the clutch plate out for a sachs
I assume it was the one below...anyone know what the difference between top and bottom? same listed spec different price...
iammooks
1,745
1,135
Looks like the Sachs one doesn't come with the CSC, but I might be wrong - half these sites use stock photos and you've got no idea what's arriving.
You'd have to confirm this, but you might have to be careful with which brand flywheel and clutch you're using. When I've looked on Euros etc. their clutch kits list under 'other information' something along the lines of 'Flywheel ManufacturerLUK' or 'Flywheel ManufacturerSachs'. That said, as long as you get the right type for your flywheel, then job is a good one, as they don't say.
Rich.T
1,609
932
Why not just get a LUK kit?
Think thats what SEAT fitted originally in the MK1s
Connor H
1,015
498
Essex
Thats what im saying to do
just the two LUK kits are differently priced but the same written spec. I wish these websites would include more f*cking info lol
Reactions: iammooks
g60stu
426
317
Reading
flywheel and bolts part numbers.
The number starting with 3 is the euros/carpartsforless number.
the number starting with 4 is the LUK part number. I did a lot of research to get check they’re right for a LCR. I guess garage will tell me tomorrow if i screwed up. :)
Clutch details to follow...
g60stu
426
317
Reading
I had the same issue. The site is so vague, but I phoned euros and gave them my reg. they will tell you the correct part and then you can order from carpartsforless (same part numbers).
Connor H
1,015
498
Essex
Cool keep us posted! Autodoc has a lot of OEM numbers to reference, which i found useful.
Bit random but...what's your surname?
My name's Connor Hobson 🤣
Hoskings lol, close!
g60stu
426
317
Reading
Well I had my clutch changed yesterday. All is good, so all the parts I supplied (as per photos above) were good for a LCR. Clutch pedal is so light now. Why do clutch pedals get heavier over time??
slightly off topic, but what is this plastic cap for (not my gearbox, just a pic off the web)?
Reactions: Connor H
Rich.T
1,609
932
The clutch cover slowly starts to sieze up over time giving a heavier pedal. Caused by hot/cold cycle and clutch dust.
The black cap looks like the gearbox breather.
Reactions: Connor H and g60stu
Fozzy84
252
137
Need to do mine soon so glad I’ve come across this thread. How much did you pay labour? Trying to work out costings. I also want a diff installed too whilst the box is out
g60stu
426
317
Reading
I paid £392 labour (supplied my own parts) at an independent VAG specialist.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Diff is a small fortune fitted.
Hope it doesn’t need shimming as that ads another 200 quid on top.
I know as it happened to my box.
And mine was only on about 60k and felt perfect before it was removed.
Badger5 Custom Map + TIP,
iammooks
1,745
1,135
Just ordered a standard Sachs clutch with DMF, but was wondering what the torque rating is for it in case I want to go for a map at some point in the future - don't forget I have a diesel, so it's pretty torquey already.
I'm definitely down on power, probably because of turbo vanes, blocked intake manifold and the like, but if when I've sorted all that I still want more oomph, just wanted to know that rating before I fit the standard clutch plate.
Connor H
1,015
498
Essex
300lbs-ft is what ive seen the standard clutch can take
Reactions: iammooks
iammooks
1,745
1,135
Hmm... The car is 236lbs/ft from standard, so I might be cutting it fine. I had heard it was something like 300 though.
I'll have to have a look at what kinds of results people are getting after remaps - I don't want to shag a new clutch as I only really want to do this job once...
Rich.T
1,609
932
I had the ARL before the car ive got now. Had a LUK clutch n flywheel when i got it.
Shortly after i had it remapped and was just under 300lb of torque.
I then drove it like i stole it for a solid 5 years without any problems.
Reactions: iammooks
