Here is my latest scan:
Car Scanner ELM OBD2
Version: 1.98.6/400986/GP
DTC report
Connection profile: Seat OBD-II / EOBD Diesel DPF var.1Date: 5/9/2023 10:50:21 PM
OBD-II
No DTC found.
19. CAN Gateway
No DTC found.
09. Onboard supply control unit09. Onboard supply control unit
DTCs: 2
00522 [0x00020A]
B11FF15: Footwell lighting, Open circuit/short circuit to B
Fußraumbeleuchtung-Unterbrechung / Kurzschluß nach Plus
Status bits: 1
Priority: 6
Frequency: 6
Unlearning index: 237
Odometer: 136106 km
Date, time: 2023.05.02 19:25:31
Status: Test failed, Confirmed
00531 [0x000213] Archive (inactive)
B11FF01: Footwell lighting, Electrical error
Fußraumbeleuchtung-Teilausfall
Status bits: 1
Priority: 6
Frequency: 5
Unlearning index: 22
Odometer: 136106 km
Date, time: 2023.05.04 20:25:57
Status: Confirmed
02. Transmission control unit02. Transmission control unit
DTCs: 1
10763 [0x002A0B]
P173400: Starter release from the selector lever sensor system
Status: Test failed (current drive cycle)
01. Engine control unit
No DTC found.
04. Power steering
No DTC found.
08. Heater and climate
No DTC found.
10. Parking Assistant 2
No DTC found.
15. SRS
No DTC found.
16. Steering column
No DTC found.
17. Dashboard
No DTC found.
42. Driver door electronic equipment
No DTC found.
44. Power steering
No DTC found.
52. Front passenger door electronics
No DTC found.
55. Headlights corrector
No DTC found.
5F. Electronic Information System 15F. Electronic Information System 1
DTCs: 1
02571 [0x000A0B] Archive (inactive)
B126CF2: Navigation system, Navigation database not enabled
Active navigation database not enabled
Status bits: 1
Priority: 6
Frequency: 2
Odometer: 136189 km
Date, time: 2023.05.09 21:51:55
Paramteric values: 02 86 7A
Status: Confirmed
76. Parking assistant
No DTC found.
I'm sure the footwell lighting errors are Coolant sensor and MAF.
Sorry for so many questions. I just want to get this car fixed so I can enjoy it again. Cheers.
