High pitch whine when ignition on
Detch
9
Hi,
I noticed recently a quite annoying thing. When the ignition is on, I can hear a high pitch whine. Like a CS/CoD flashbang.
I'm sure that when I turn the ignition off - the sound is gone. It's (probably) not related to the engine, music or road noise. I can hear it with and without music, while driving, stopped etc.
My car: late 2015 (MY2016) Cupra 280 5D.
Any ideas what that might bet? Because it's driving me crazy.
Signor Whippy
232
God's Country
My old mk2 cupra used to do this. Never found the cause out though. Like aBoijj says, could be the fuel pump priming but it does seem to go on for a while and seems to come from under the bonnet from what I can remember.....
aBoijj
104
Midlands
The priming of the fuel pump is essentially it doing the same thing as it does when the engine is running, just pre-pressurising the fuel lines before the engine is started. Once the engine is running, the engine noise often drowns this kind of thing out. With the ignition on and engine not running, it stops after a few seconds in most cars.
Does the noise go on indefinitely when the engine is not running, or does it stop after a short while?
Detch
9
youtu(dot)be/yFVLPxfMcMQ
I've recorded it when I've arrived at my work. The engine was warm and turned off, same with AC, music was muted. Because it was really quiet, my mic recorded a lot of static noise. However you can hear the really high pitch whine in the background.
When I turn the ignition off - it goes away.
