Light Assist (HBA) memory. How to activate.
Feb 22, 2024
15
Hello! I have an Octavia MQB Evo (NX4). I want to activate the high beam memory. There are 2 ways on the Internet, but they both don’t work. Maybe you have some ideas?
1)
Light Assist/High Beam Memory
With this modification when starting the car the Light Assist/High Beam will keep the last setting and will no longer restart by default.
1 - Module 09 Central Electrics - Adaptation
3 - Fernlicht_assistent:
4 - Fernlichtassistent Reset: change value to not activate(default: active)
Prerequisites: SFD Unlock required!
2) The application in obd11.
Feb 22, 2024
15
Yes, I coded and alas for only 10 minutes. Or maybe there is a corrected parameter or it is possible to make a device that will send a signal to the CAN bus that emulates pressing a lever? We made KLR emulators for the steering wheel.
Not possible to do. You van code but it wont work. Only for 10 minutes
