Forbez
Huge Member!
Feb 11, 2004
5,877
S.Wales
Visit site
Dunno if this is of any use, but with the amount of "part number request" posts i've seen recently thought it would be a useful post.
If anyone has anymore part numbers, please add them, with a little description, and then we can have a simple list of part numbers, and single thread with all the part numbers we know
Common Ibiza part numbers, some with possible prices also:
inlet manifold gasket 058 129 717d
inlet mani bolts x8 n100 801 02
Turbo to downpipe gasket 1J0 253 115 R £4.31
Downpipe studs N 90767801 £0.35 each @ 4
4BAR FPR is 078133534C audi part number
MAF: 06A906461D
MK3 cupra Strut brace: 6K0071670
N75 valve: 058906283F - F version
Seat: Oil Temp sensor: 1H0919563
Interior cupra flag badge: 6K0-853-681-JHQ
passenger side headlamp - 6K2-941-029D
Coil Packs: 06B 905 115 R (Various er variations)
Euro Car Parts coil packs for the 1.8t ibiza........ 413 44 0480
Bolt down Coilpacks from GSF 0040.402.009 thats the beru number, on a sticker (which i guess is gsf number) is 92533
Engine Cover bits
Engine cover screws: 908 011 01
Retaining washers for the above: 906 633 01
Body Parts
Cupra front bumper - 6K0-807-221-R-GRU
front r/h wing - 6k0 821 022d
front l/h wing - 6K0 821 021d
Side Honeycomb grills - 6K0-853-653-B-79Y
Drivers side door handle:6k4839205c GRU
Front tow eye Cover 6k0 807 155 A gru and 6k0 807 156 a gru
Bump strips
Grey:
Bump Strip front :Front - 6K0807225(H79Y) - £14.23 or G79Y if you have headlight washer.
Bump strip rear: Rear - 6K6807425G79Y - £17.46
Black: (better for colour coding)
Front: 6K0 807 225 D B41
Rear:6K0 807 425 F B41
SEAT Sport 5 speed gear knob - Part No. 6L 0 064 325 A
Drivers side window motor: 6K3 837 402G
Leon Cupra R splitter : 1ml805903 @ £18.37
Cupra R wheels, OZ SuperT centre cap: 1M0 071 400 A
Plastic boot / tailgate liner: 6K6 867 601 E then add either B41 for black or 73Y for dark grey to the end of the part number.
Cupra R centre console Gauge pod: 6K0 863 263 or 6K0 863 263 01C
Switch for clutch pedal:8D091107A
Aero Wipers
Front Wiper Arms (these are drivers side arms, need two rather than one driver and one passenger) x 2 - 6X2 955 410 C - £30.88
Front Wiper Blade x 2 - 6X2 955 426 A - £10.94
Front Wiper Cap x 2 - 1J0 955 205 A 01C - £0.91
Rear Wiper Blade x 1 - 6Q6 955 425 A - £4.53
Rear Wiper Arm x 1 - 6Q6 955 707 C - £12.36
Rear Wiper Cap x 1 - 6Q6 955 435 B - £1.52
Interior handles (rubber coated) for cars with electric windows.
Passenger side:
6K0867171 90L - blacksea / dark grey
6K0867171 54H - black
Drivers side:
6K0867172B 90L - blacksea / dark grey
6K0867172B 54H - black
Cambelt and water pump (for AQX engine, not sure if this differs between engine models)
Cambelt 06B 109 119 A
Tensioner 06B 109 243 D
Water pump (metal impellor): 06A121011T
Seal:06A121119
Cambelt Damper: 06B 109 477
Cam chain tensioner : 058 109 217
Parts needed for the KO3s conversion:
Shield, heat deflector, push on connector, lambda probe: 6K0 972 936 B
Red seat belts
Left
11/00 ------->2/01 6K3 857 705 C 1NQ
3/01 -------->5/02 6K3 857 705 E 1NQ
Right
11/00 ------->2/01 6K3 857 706 B 1NQ
3/01 ------- > 5/02 6K3 857 706 D 1NQ
Rear seat belts
Left
6K0 857 805 G 1NQ
Right
6K0 857 806 G 1NQ
Center lap belt
867 857 713 B 1NQ
Camshafts
058 109 021 M intake camshaft ARY, AUQ, AMK, BAM (leon)
058 109 022 B exhaust camshaft AMK, ARY, AUQ, BAM (leon)
058 109 021 B intake camshaft AQX AYP (ibiza)
058 109 022 B exhaust camshaft AQX AYP (ibiza)
Lambda probe before cat: 06a 906 265 N Approx £90
Lambda probe after cat: Part no. 6K0 906 262 B Cost from dealership - £96.21 + VAT
Manufacturer Part........................................Bosch Part No:
06A906260N (Front sensor)...........................0258006213
6K0906262B (Rear Sensor)...........................0258006266
Track rod ends: (see this thread as they seem to differ)
http://www.seatcupra.net/forums/showthread.php?t=60533&highlight=ibiz*+part*+number
LHD passenger mirror (i believe these are the right numbers for the LHD passenger mirror)
housing 6K1857508H01C £71.53 + VAT
cover 3B1857538BGRU £18.96 + VAT
glass 6N1857522C £21.17 + VAT
Oil Filter
part no. 06A 115 561 B £2.86 including vat (from VW)
Sump Plug Part number - N90813202 Price - £0.98
Cupra sideskirts [primed and ready for painting]:
left: 6k0 853 853 A GRU
right: 6k0 853 854 A GRU
Sideskirt jackpoint caps [primed]:
front left: 6k0 853 455 B GRU
front right: 6k0 853 456 B GRU
rear left: 6k0 853 455 C GRU
rear right: 6k0 853 456 C GRU
sideskirt back cover left: 6k0 853 657 GRU
sideskirt back cover right: 6k0 853 658 GRU
centre front honeycomb grille with 'S' logo: 6k0 853 651 AA
centre front honeycomb lower grille: 6k0 853 677 C
left foglight housing for cupra bumper: 6k0 807 929 A
right foglight housing for cupra bumper: 6k0 807 930 A
cupra left front foglight: 6k0 941 703 A
cupra right front foglight: 6k0 941 704 A
Powerflex bushes.
- PFF85-204 Front Lower Wishbone Rear Bush
- PFF85-201 Front Lower Wishbone Front Bush
- PFF85-202 Front Eye Bolt Mounting Bush
- PFF85-250 Front Subframe Bushes
- PFF85-232 Steering Rack Bush
Passenger side apperture door seal : S6K3867365G 15.41 + VAT
Suspension Mounts and Bearings
Front
6N0412331E
(6N0412331D)
Rear
191 512 333 (Lower)
191 512 335 (Upper)
Top mount bearings... (taken from the box)
6N0 412 249 C
Fuse box:
1J0 937 555 cover for fuse holder
for models with battery: 44AH
1J0 937 555 A cover for fuse holder
for models with battery: 60/70AH
1J0 937 555 B cover for fuse holder
for models with battery: 72AH
Outside Temp Sensor - Sensor in the wing mirror: 6K0 919 379
Does anybody knows the partnumber for a passenger side mirror?
Just doing an oil filter change so here's the filter number
part no. 06A 115 561 B and it cost me £2.86 including vat :-o
Got it from VW as my local seat dealer is full of idiots :whistle:
as above, just done filter and oil change, when i got a filter also got a new sump plug : -
Price - £0.98
