Okay first things first.. you will need..
a small metal works...Mackays of cambridge did mine
get a piece of Aluminium cut 6mm thick by 7 1/2 inch x 2 1/2 inch
next step you have 3 options
with a power drill and a 54mm metal hole saw
ask the small metal work if they can cut a 54mm hole into the piece of metal.
find someone with a bench drill.
left with something like this
it'll be tight aand will have to file down the top so the bottom sits in and you push firmly in (not gonna go anywhere)
basically done!
just plumb in guage push into hole,
go for a drive (no need, but good excuse for one!)
need to polish up, i did mine a bit but need more to look 100%
need to clean my cabin!
basically done!
