Aluminium Din gauge holder
redcupratdi
Offical SCN Pole Dancer
Oct 13, 2005
755
cambridge
Okay first things first.. you will need..
a small metal works...Mackays of cambridge did mine
get a piece of Aluminium cut 6mm thick by 7 1/2 inch x 2 1/2 inch
next step you have 3 options
with a power drill and a 54mm metal hole saw
ask the small metal work if they can cut a 54mm hole into the piece of metal.
find someone with a bench drill.
left with something like this
it'll be tight aand will have to file down the top so the bottom sits in and you push firmly in (not gonna go anywhere)
basically done!
just plumb in guage push into hole,
go for a drive (no need, but good excuse for one!)
need to polish up, i did mine a bit but need more to look 100%
need to clean my cabin!
Triple D
hhmm wonder where you got that idea from :whistle: mines better though :p
Triple D
A good tight fit mate thats how ;) push both the plate and sterio in together and it will be a nice snugg tight fit ;)
Triple D
Oh and forgot to add mine cost absolutly £0 :D as it was an off cut in the scrap, they cut it for free, and i drilled the holes when i got home. The sterio keys were left in my car when i picked it up so no need to buy or pay seat to move it around :D. Then just finished the piece off by rubbing it with some wire wool and getting rid of a few scratches.
gazjones
thats mine cost me 4.99 just a universal din blanking plate with bit of trimming
although ive messed it up now by adding ic spray switch but took spray off right away so need to make a new one up
think ill get aluminium one and paint it black!
