We've got a 2001 VW sharan 130 TDi in at work at the moment suffering badly from boost problems. It's basically not boosting at all, then has the odd spike where it boosts momentarily.
Any help would be much appreciated!!
It has this fault code stored:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 038 906 019 FC
Component and/or Version: 1,9l R4 EDC 0001SG 1455
Software Coding: 00002
Work Shop Code: WSC 00020
Additional Info: WVWZZZ7MZ2V013043 VWZ1Z0A1668664
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
The turbo itself has been checked out by a turbo specialist and we've tried replacing two pressure sensors so far and the MAF sensor.
Today I took some logs of 2nd and 3rd gear pulls with my VAG COM as it's still not right.
I've logged blocks 3 & 11 on separate runs and produced these results (sorry haven't figured the code for the best way to display them on here yet):
Group A: '011
Engine speed Spec. intake press. Actual intake press. D.cycle MAP
TIME 2850-3150 2000-2150 2000-2200 40-95%
MARKER STAMP /min mbar mbar %
6.19 1470 1468.8 2539.8 94
6.71 1554 1417.8 2539.8 94.4
7.21 1575 1397.4 2539.8 94.4
7.64 1575 1295.4 2539.8 94.4
8.06 1596 1264.8 2539.8 94.4
8.51 1617 1275 2539.8 94.4
8.94 1659 1785 2539.8 94.4
9.38 1680 2182.8 2539.8 63.8
9.82 1743 2244 2539.8 63
10.27 1806 2254.2 2539.8 64.5
10.71 1869 2274.6 2539.8 66.1
11.14 1932 2284.8 2539.8 66.9
11.58 2016 2284.8 2539.8 68.9
12.02 2058 2284.8 2539.8 70.9
12.52 2142 2274.6 2539.8 73.3
13.03 2205 2254.2 2539.8 76.1
13.55 2289 2233.8 2539.8 82.1
13.95 2352 2233.8 2539.8 82.5
14.39 2394 2223.6 2539.8 85.7
14.83 2457 2213.4 2539.8 91.6
15.27 2520 2203.2 2539.8 93.2
15.7 2604 2193 1397.4 19.9
16.09 2709 2182.8 1591.2 60.2
16.53 2856 2172.6 2509.2 94.4
16.97 2982 2152.2 2539.8 94.4
17.41 3108 2142 2458.2 94.4
17.85 3234 2131.8 2539.8 94.4
18.31 3339 2121.6 2539.8 94.4
18.87 3465 2121.6 2539.8 94.4
19.36 3633 2111.4 2539.8 84.1
19.78 3759 2111.4 2539.8 94.4
20.22 3885 2111.4 2539.8 94
20.66 4053 2091 2539.8 94.4
21.1 4200 2029.8 1907.4 86.5
21.54 4347 1999.2 1866.6 80.5
21.98 4473 1989 2499 94.4
22.42 3738 1060.8 1723.8 43
It seems to me that the actual pressure reading is incorrect as it always keeps coming back to 2539.8 no matter what the ECU is requesting, other than a couple of odd spikes.
If it would help to get some more logs of any other data just let me know!
Thanks for taking the time to look!
Martin
1 Fault Found:
P1557 - 35-00 - -
Group A: '011
Martin
