Yep, i had done everything to mine before i had upped the power, changed suspension, clutch, brakes, exhaust and fmic all changed, then upped the power. Best way IMHO
Same here
'Slick' - while I'm asking questions... what do you make of your Short Shifter? What are the pros / cons, if any? Worth the money?
Cheers for your advice.
T
Wicked piece of kit for the money, i hated the OEM gear shift travel, it has a short gear length anyway, so to add long shift travel to already very short gears in 1st and 2nd, you would lose out in 0-60 tests as most of the time your changing gear!
With the JBS shifter its shorten it "just" enough to make it more a sporty and solid feel... i didnt have the horizontal short shifter fitted only the vertical changed and its a whole alot better... Actually has a sporty gear box feel to a racey feeling diesel...
I love it and even friends of mine that have driven mine have loved, two of which went out and brought one...![]()
Very cheap mod in my eyes and great improvement...![]()
When i get it back the car, i should really meet up with a few people Derv people and show them what the work has done... MK is good for roundabouts!![]()
Have a word with Allards Timbo, they are installing both Nitrous and Propane on mikes audi at the minute, along with injectors, and a few other things.
i guess that could be a small problem it being a small window of turbo.... makes me think thou....
Bi-turbo....hmmm that would be intresting....
It just gets worse! ;o) When we're driving round in our ATB'd Bi-Turbo'd, Propane & NOS injected 16V 2.0 TDIs, what will do next? Has anyone ever converted a 2.5, 3.0, or 4.2 TDI from the Audi range into a Golf/Leon/A3 shell? Like most things, I imagine it can be done, but at ridiculous expense... The car may end up being a little nose heavy mind!
T
Funny that - I was thinking about a RS4.2... V10 TDI yesterday too...
So Mike, you consider yourself a diesel man rather than VAG? What other cars have you owned, pre the Cupra?
I'd find it hard to buy outside of the VAG group... Only ever owned Golfs - 1 Mk1, 2 Mk2s, 2 Mk3s, and now the Mk4...
Should probably keep m'head down, this being a Seat forum an'all!
T
