Status
Not open for further replies.
cant see you enjoying tennis daz you poof!
just finished fitting my mates screen, hideaway master unit, freeview tuner, sub and amp and all cabling, not fun!
that looks like a 052, i thought they started on a 053 upwards, have you got pics of the turbo? 8 compressor blades compared to 12 on the k03, also i believe it has one vag feed to the actuator on the k03s as opposed to 2 on the k03?
ummm topmount? lol you should make a day of it, i'll come round and fit the HIDs too if you want?
grounding kit isnt too much of a problem phil, just need some measurements from the engine bay, i'll look into it
I got the top mounts from here...
http://www.vwspares.co.uk/ibiza99_suspension.php
Part bnumbers (taken from above site)
Front
6N0412331E
(6N0412331D)
Rear
Replaces OE Ref:
191 512 333 (Lower)
191 512 335 (Upper)
Top mount bearings... (taken from the box)
6N0 412 249 C
Can someone check these with etka to see if theyre ok first.
Hope that helps.
So From AVS, i need to order
Front Top Mount Part number: 15870 Price:£8.30 ea
Rear Top Mount Kit Contains 2 upper & 2 lower mounts
Part number: 14958 Price: £6.69
Then the other part numbers, are they from ECP?? or AVS, if so under what name, as i dont seem to be able to find them.
Cheers Tom
Status
